Kubota engine oil recommendation
   / Kubota engine oil recommendation
The Kubota 10W-30 diesel engine oil I bought from my dealer had an API CI-4 rating. The info on the Kubota website specifically says not to use CJ-4.
Non-EGR:
API Classification
CF, CF-4, CG-4,
CH-4, or CI-4
(do not use CJ-4)
External EGR:
API Classification
CF,CI-4 (do NOT use
CF-4, CG-4, CH-4,
CJ-4)
   / Kubota engine oil recommendation #22
I addressed this previuosly with a Kubota technician. He said that CJ-4 rated oil is just fine and the web site and manuals will be updated as quickly as any large corporation can move...which he said was "pretty slowly".
The warning on the web site and manuals was due to the introduction of low sulpher fuels and the concern early on for possible injector issues. He said that low sulpher fuels are widely used now and the new CJ-4 oil addresses their earlier concerns. They just have not made the written or web site changes. He also said this was an "unofficial" comment to me because they have to stay with what is in print for legal reasons.
Don't worry about CJ-4 spec oils. They will work perfectly well with off-road OR on-road low sulpher diesel.
Most diesel oils are now CJ-4 rated and any that aren't are soon to be sold out of inventory.
Hope this helps. :D
   / Kubota engine oil recommendation #23
A cynical person might think Kubota wants to use up their stock of Kubota brand oil that doesn't have CJ-4 on the label, and then it will be all right to use it when their bottles are labled that way.
   / Kubota engine oil recommendation #24
I have a B7200 HST Diesel (used). I can't seem to find how much oil the crankcase holds with filter change. Can anyone tell me?
Michael
   / Kubota engine oil recommendation #25
:eek: Fortunately, there are no cynics here!! :eek:
:D
   / Kubota engine oil recommendation #26
At 150 hours I switched from 10w-30 kubota oil to 5w-40 Rotella Synthetic. I'm sticking with this until spring. Then I'll go with the 15w-40 Rotella. The kubota tech I spoke with about 2 months ago said it was just fine to do that...off the record.
I use the Rotella 5w-40 Synthetic year around in northeastern PA. Seems to be a good fit. Run it in the motorcycle, push mower, and power washer too.
   / Kubota engine oil recommendation #27
Not too jack the thread here, but would it be better to run a 5w40 or 15w40 that is CJ-4 than to run a 10w30 that is not? Our 1523 was built June 2007, and I cannot seem to find a 10w30 synthetic that is CJ-4. MF calls for 10w30, but a minimum of CC, guess they need to update the manuals. :(
   / Kubota engine oil recommendation #28
I would run the 5w-40 CJ-4. If you can find the Shell Rotella T Synthetic, at something like Walmart or another discount store, I don't think you'll find a better bargain for a quality product. If you were down south, I might suggest something like the 15w-, but in Ontario, you should be good with the 5w-40 year-round.
   / Kubota engine oil recommendation #29
I think Amsoil makes one.
I'd just use Rotella T 10-30 or RTS 5-40 and not worry about it. ;)
I changed my oil last weekend with Kubota 10W-30. The new kubota 1 gallon 10W-30 oil container has a slightly different shape than the old container. The part numbers are the same however the new oil includes the CI-4 Plus API rating whereas the old container does not (it only goes to CI-4).
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
2016 WESTERN STAR 4900 SB DAY CAB (A58214)
2016 WESTERN STAR...
Scrap Water Tank, Asset# 61 (HAS HOLES) (A59076)
Scrap Water Tank...
JRB HANG ON WHEEL LOADER (A58375)
JRB HANG ON WHEEL...
2017 Mitsubishi Outlander AWD SUV (A56859)
2017 Mitsubishi...
BETTER BUILT FUEL CELL (A58214)
BETTER BUILT FUEL...
