Kubota Engine Stops suddenly.
   / Kubota Engine Stops suddenly. #1
wagonwagon
Pa, east of Pittsburgh
I just recently became the owner of a Kubota BX24, by way of eBay. The tractor has less than six hours on it of which I've put @3 of them on.
I followed tge manfg. procedure to try and bleed the air from the system, no Help.
I was wondering if there are any known bugs from the manfg. that might be causing this?
It seems to happen randemly, ie..ie.. moving, while standing still and loading the engine while turning the mower on Thasnks.
   / Kubota Engine Stops suddenly. #2
I don't think it is fuel as it would stutter down and not stop suddenly - sounds electrial. It sounds like there is a sensor trying to protect your safety. Does that tractor have a seat sensor? Check all the wires and connections for loosness or rubs that may be shorting out.
my $0.02
jb
   / Kubota Engine Stops suddenly. #3
I agree, good chance one of safety switches, not fimilar with the BX model but i had simular problem with safety switch on the seat, switch was fine, i just had the seat adjusted to firm and my weight was not enough to keep the switch closed. Turned the knob to loosen seat and was fine then.
2019 RBR Venturi 380 (A55301)
2019 RBR Venturi...
2019 Chevrolet Cruze Sedan (A53424)
2019 Chevrolet...
2005 Military Trailer (A53424)
2005 Military...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
1999 Ford F-450 Mason Dump Truck (A53422)
1999 Ford F-450...
17201 (A55852)
17201 (A55852)
