Kubota F2400 Overheating - Thoughts Please
   / Kubota F2400 Overheating - Thoughts Please #11
I couldn't keep my 4700 JD Tractor cool mowing grass every week.
I removed Tstat against everybody's advise, & it's ran flawless all season long :D
I was raised being told to do what you did. Now having mechanics of tractors and heavy equipment tell me not to, water moves too fast for proper heat transfer. But for me I have found keep it clean and have no had any real temp issue. A dirty air filter will cause more temp issues than you would think. Diesels love air.
Think I got it working now.
I did take off the new thermostat and test. Should off seen the antifreeze go all over me and garage! What a hoot.
Replaced the radiator cap.
Drained some oil, as it was too full.
Thank you everyone.
   / Kubota F2400 Overheating - Thoughts Please #13
I have a Kubota bx2200 and abx220 these are though to keep cool I have tried many things best change to date is installing a five blade fan from a bx2680 (needed to be cut down about .50")
   / Kubota F2400 Overheating - Thoughts Please #14
2200 hrs on Kubota F2400 front mower/72 inch deck.
Hello, hope someone can help me through this.
Between strip screws, broken bolts, etc. my mower's been down awhile. Mower Overheating (in 20 minutes) issue when on load, can idle all day long!
What I did...
Oil change, (old oil looked black)
Replaced thermostat, water pump and fan belt.
Flushed out with water, all hoses and radiator/inside & out
Washed down the whole darn thing.
Still overheating
Tractor took a trip to local Kubota dealer; what they said they did...
Fixed 4wd not engaging correctly
Flushed radiator/system?, twice.
Install 3 new blades.
Still overheating,,,,also a blade fell off!!!!!Really!
Then a friend...
Took Radiator off, went to local radiator shop, totally re-cored, re-installed.
Still overheating
Ugh
Thoughts, besides buy a new mower?
Maybe if you post this in a general tractor forum you might get more ideas. It's likely a problem common to all diesels, and this forum is fairly limited in size..
   / Kubota F2400 Overheating - Thoughts Please #15
No, not a common problem with "all Diesels"!
   / Kubota F2400 Overheating - Thoughts Please #16
The OP started and finished the thread Sep 2017….🥴
   / Kubota F2400 Overheating - Thoughts Please #17
Does it have fan shroud is the fan the right size all good questions
2006 Ford F-350 Forestry Dump Truck (A51692)
2006 Ford F-350...
1994 International 3800 Bus (A55852)
1994 International...
2021 JLG T350 PORTABLE ELECTRIC SCISSOR LIFT (A52705)
2021 JLG T350...
2011 Ford Explorer SUV (A53424)
2011 Ford Explorer...
2018 Ford Explorer AWD SUV (A53424)
2018 Ford Explorer...
UNUSED FUTURE FT46 - 46" HYD MULCHER (A54757)
UNUSED FUTURE FT46...
