ch1ch2
The mower is stored outside and covered. I replace the fuel supply rod. I cleaned out the tank and found that the old fuel supply rod was coated with rust. Since I think I have done everything that would be from the fuel tank supply to fuel tank return, for the moment, let's assume that is not the problem. What else could cause this problem? I appreciate everyone's help.
Joe
I am going with fuel also. I had a metal tank that started rusting and I gave up on it and bought a new tank. I have another tractor with a plastic tank. It stopped flowing fuel at times. I took off the tank and could not find anything until I washed it out with a water hose. It took 4 times until stuff stopped coming out.
