Kubota F3036 Hyrostatic drive problem
   / Kubota F3036 Hyrostatic drive problem #11
The Cylinder block pump and motor are the main HST components. yes it could be something in one of them but without more diagnostic info it will all be guesses.
If the HST on the "F" series is similar in design to the "BX" series CUT you will have multiple test points to check pressure at.
These would be:
a charge pressure.
Forward system releif
Reverse system relief
thanks for that information and please excuse my ignornace but wondered if you could describe these test points and would you have any idea of what pressure would be taken as normal ? agian thats for taking time to respond:eek:
   / Kubota F3036 Hyrostatic drive problem #13
My F2560 was acting similair but stays at the same speed at all times,changed everything with Kubota products with no luck,was told that a suction line could be coming apart inside and not getting enough fluid,how much does system hold ,parts guy told me 3 gallons butwas spitting out and foaming up out filler cap,drained 1 out sight glass showed 3/4 on glass?whats rite haven't found amount?
   / Kubota F3036 Hyrostatic drive problem #14
Did you get a solution to the issue as I have having a similar one? What was the answer?
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
2020 CATERPILLAR 259D3 SKID STEER (A51246)
2020 CATERPILLAR...
Adams 5 T Spreader (A53472)
Adams 5 T Spreader...
1266 (A50490)
1266 (A50490)
1998 Talbert TDW-35S-HRG-1-T1 Detach, GVWR 84,300 (A52384)
1998 Talbert...
