Kubota Front end Snowblower (B2781A) not raising
   / Kubota Front end Snowblower (B2781A) not raising #1
Shane77624
Kubota B2320
First let me say hello.
I have a B2320 with a B2781A front end snowblower. The chronology of issues are as follows.
1. After hookup this year, the quick connect hydraulic fittings were leaking like a sieve.
2. Replaced the o-rings in the fittings and problem seems rectified.
3. Hydraulic cylinder will not lift the blower.
4. Hoses just "jump" when the cylinder is activated (FEL works fine)
5. 3-pt hitch works fine
6. when pressing the valve in the quick connect fitting of the blower the oil that comes out is pure foam
7. the oil at the male connector on the tractor looks normal
8. I assume the blower lowers normally, but cannot be sure since I cannot get it to raise up
9. I disconnected the line and the blower raised up with fluid flowing into the bucket.
10. It seems that each time I cycle the up/down it raises a little less.
11. With the line disconnected the cylinder completely retracted, but now it is leaving 1-1.5 inches exposed instead of retracting fully.
12. It seems to work when I remove the pressure from the line and stops working when the pressure builds up over a few cycles
13. Well, it's been sitting for about 3 hours and now the blower will not move up the cylinder just bumps like it has a block in it that will not allow it to go up.
14. Is the fact that while the cylinder is fully contracted (Blower up) it slowly lowers (with the tractor running) on its own any indication of something?
15. I disconnected the cylinder (removed weight) and it still doesn't move...it just bumps.
Any and all help is appreciated.
   / Kubota Front end Snowblower (B2781A) not raising #2
Not a mechanic, and certainly not an expert, but my personal experience when something is all of the sudden screwy with the hydraulics is that I have connected the lines incorrectly. So my initial thought is that you should make sure everything is connected correctly.
Is the hydraulic fluid reservoir full?
Foaming fluid is probably air getting into the system somewhere, possibly those new connections you repaired.
   / Kubota Front end Snowblower (B2781A) not raising #3
You may have the hydraulic lines crossed instead of paired. Check them. Youmay also have a line full of air. Cycle the control(s) 4 or 5 times full stroke to bleed them off. Don't drop the valve into float while you are doing this.
378811 (A51573)
378811 (A51573)
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
2016 LOAD MAX 24 GOOSENECK (A52472)
2016 LOAD MAX 24...
2010 Honda CR-V Multipurpose Vehicle (A51694)
2010 Honda CR-V...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
HLA 2500 8' Snow Pusher Bucket (A52349)
HLA 2500 8' Snow...
