kubota G1800 fuel shutoff
   / kubota G1800 fuel shutoff #1
ashcraft
when i cut the ignition switch to the off position the engine continues to run..
i depress the starter stop solenoid to kill the engine..
the igniton switch in the off positon kills the circuit to the fuel guage and the temp guage but as i said above the engine continues to run until i depress the starter stop solenoid...
has anyone had this problem and if so please tell me what the remedy is...
   / kubota G1800 fuel shutoff #2
You have an electronic controller box on the left side of engine. 1st use a test light and see if stop solenoid gets current when key is turned oon then turned off. A quick check is to turn switch till glow lamp comes on , then hold in position . Lamp should go out in 10 seconds approx. If not test controller. Not a cheap part .
LANESHARK LS3 LOT IDENTIFIER 148 (A53084)
LANESHARK LS3 LOT...
RYOBI 18V BRUSHLESS ELECTRIC 16" PUSH MOWER (A51248)
RYOBI 18V...
STORAGE FEES (A53426)
Kubota Salt-Spreader (A52384)
Kubota...
TAKEUCHI TL230 SERIES 2 SKID STEER (A51246)
TAKEUCHI TL230...
2010 International 4300 2,000 Gallon Water Truck (A52377)
2010 International...
