plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 3,858
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
I am considering the purchase of a Ventrac 4500, but am undecided on engine option. I've narrowed it to either Kubota gas or diesel. My expected use is summertime mowing/brush hogging.
My inclination is diesel, for two reasons. One is fewer problems with fuel, such as if the unit is parked for a while while the gas ages. With a diesel unit I am more comfortable letting the machine sit for a longer period of inactivity than with gas. Such as over the winter. The other reason is perceived longer life in a diesel engine. I am not as sure about that, as Kubota supposedly uses very similar blocks for both the gas and diesel engines, and each runs at 3600rpm.
The factory tells their dealers to push the gas engine, which is more powerful at 32hp. The diesel is only 25hp and is not turbocharged. I don't have a practical way to test the diesel power for my needs, but from an earlier test drive of a gas unit plus reports from diesel owners it should be fine.
Again, I am leaning toward diesel but don't like going against what the factory recommends, which is the Kubota gas engine. Have I missed anything to consider between the two engines?
