Kubota HST driveshaft issue
Status
Not open for further replies.
   / Kubota HST driveshaft issue #1
nrockow
Upstate New York
Kubota B2630
I have a Kubota B2630hst that I recently wrapped a tomato cage around the driveshaft. After 4 hours of prying and unraveling, the wire is out. However, there seems to be more vibration in the tractor than before. It could be my imagination though. I have only 8 hours on the machine. I have run the tractor and put my finger against the spinning shaft and can feel a slight vibration. Considering that this is a straight shaft without any u-joints, I am not sure if there can be any runout at all without damaging the machine. I have had a friend of mine who is a machinist (and very knowledgeable about tolerances) look at it and touch the shaft when it was spinning and he seems to think that it should be ok. Estimated about 10 thousanths of an inch runout. But a tractor mechanic he is not. Can anyone tell me if there is a runout tolerance for this drive shaft and if so, what it would be? I posted this question in another forum but the response was limited. I am hesitant to use the tractor without some more input from knowledgeable people. Thanks for the help.
   / Kubota HST driveshaft issue #3
Duplicate thread. Closed.
   / Kubota HST driveshaft issue #4
Status
2013 PETERBILT 367 (A55745)
2013 PETERBILT 367...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2017 JOHN DEERE 333G SKID STEER (A53843)
2017 JOHN DEERE...
GROUND PROTECTION PAD 8X4 15 COUNT (A55745)
GROUND PROTECTION...
2014 FREIGHTLINER CASCADIA (A55745)
2014 FREIGHTLINER...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
