kubota hydraulic block to add lines??
   / kubota hydraulic block to add lines?? #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Anyone seen one of these?? Not sure what it is or were it goes or for what models?? Remotes would be nice to add to my L series, but not worth the money to do so IMO. Is this one of the peices of the puzzle??
Kubota Hydraulic Block
   / kubota hydraulic block to add lines?? #2
Yes - it's a hydraulic block, but I dunno which model(s) it fits. There are several variations of this on Kubotas. The two holes with o-rings are normally covered by a two-bolt cap, with passage that connects the two ports. It is intended as the spot where close-coupled factory hydraulics can be bolted. A block like the one in your pictures can be used instead for connecting remote hydraulics with hoses.
One port is the oil supply and would go to the inlet port of the remote valve. Regarding the second port, there's a good way to connect it and a not-so-good way. The good way is to connect it to the Power-Beyond port on the remote valve. This way the 3-point hitch will still work when the remote valve is in use. In this setup, exhaust from the remote valve goes to the reservoir in a 3rd hose. If the second port on the block is use for the remote's exhaust flow, 3-point hitch and the remote valve function will interact, maybe objectionably. But if you plan to strictly use just one at a time it would work ok.
   / kubota hydraulic block to add lines?? #3
I used a similar block for an older B series...the block attaches to the side of the pump casing above the rear axle...you remove a by-pass plate and replace it with the block...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
2016 Ford F-150 Crew Cab Pickup Truck (A53422)
2016 Ford F-150...
WHISPERWATT DIESEL POWERED GENERATOR (A53843)
WHISPERWATT DIESEL...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
