Kubota Hydraulic Fluid vs. Generic
   / Kubota Hydraulic Fluid vs. Generic #1
Toddbo34
Santa Fe, TEXAS
I have a Kubota M7040HDC and it's time to change the hydraulic fluid. I was wondering if there is an equivalent generic different brand of fluid I could use. The Kubota fluid is 2 times more expensive than what the local parts sells. Kubota calls for the Kubota UDT or SUDT. Any advice is appreciated.
   / Kubota Hydraulic Fluid vs. Generic #2
If it says Kubota UDT compatable then it is ok to use it.
Some folks will say only use Kubota fluid only, I have used Mystik fluid for 6 years in two different Kubotas with no failures with a total of 662hrs between the both, I figure it is ok to use Mystik, Rotella or whatever Kubota compatable fluid you find locally.
   / Kubota Hydraulic Fluid vs. Generic #3
I have had good luck with the Hyd oil from TSC.
My neighboor had good luck with oil from NAPA.
Booth of us HAD BAD LUCK with NAPA oil filters. It would cause the Hyd system to whine extremely loud. Replaced the filters with KUBOTa filters and the whine almost disappeared.
   / Kubota Hydraulic Fluid vs. Generic #4
Most of the generic fluids will meet UDT spec, but I've never seen one thats meets SUDT. Some equipment does have clear benifits from SUDT, your tractor is not one of them. I'd still not use the cheapest around. New Holland 134 is alot cheaper and a very good oil.
   / Kubota Hydraulic Fluid vs. Generic #5
The local kubota dealer here in Nothern Colorado does not sell Kubota hydraulic fluid, they sell Case HY-HYTRAN Ultra.
   / Kubota Hydraulic Fluid vs. Generic #6
Not sure about others but I know TRC's UTF line meets and exceeds the SUDT spec. Of all the tractor manufacturers I think Kubota does have one of the highest spec. fluid's there is. The SUDT spec. is a high one and one reason many non OEM fluids do not meet it. As many owners here can confirm just switching from a UDT spec. fluid to a SUDT spec. fluid often quiets down chatter and whine in their equipment.
   / Kubota Hydraulic Fluid vs. Generic #7
Valvoline Unitrac works well for me.
I've read that Valvoline makes the Kubota's UDT.
   / Kubota Hydraulic Fluid vs. Generic #8
I'm trying to find a operators manual for a KUBOTA tractor model: L3202DT, can anyone help?
   / Kubota Hydraulic Fluid vs. Generic #9
:welcome:
suggest you start a new thread with question in the topic...
   / Kubota Hydraulic Fluid vs. Generic #10
Messick, when you wrote, your tractor is not one of them, can you elaborate on the distinction between models that do or do not need SUDT? Is it the model that determines this or age/production year?
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2015 INTERNATIONAL LONESTAR SFA 6X4 ROAD TRACTOR (A52706)
2015 INTERNATIONAL...
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
MILLER XMT 350 WELDER (A55745)
MILLER XMT 350...
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
