Kubota issue with high idle/ running rich
   / Kubota issue with high idle/ running rich #1
Mitch01
ottawa
kubota
I have a kubota compact dump loader model KC51
With a small gas Kubota engine model GH170-1-E2-GCLY
It has a mikuni carb
When I inspected the machine I found that the thottle was seized wide open bad and the thottle cable was also seized and junk.
I have un-seized the thottle and replaced the cable and thottle control.
Now the machine runs rich?
I opened the carb and its very clean looks new.
Thought it was cause the air breather was off but nope it makes no differance.
I'm quessing it has to do with idle mixture/ fuel mixture but on these carbs theres retarted nipple things and only one top scew.
What is the default mixture and where are the mixture scews
thanks all info will help
Fixed the issue the thottle shaft was loose i had to re-solder it on and a small hole was in the intake boot. Now just adjusting/tuning the carb
Rooster Weathervane (A55853)
Rooster...
JOHN DEERE 6430 PREMIUM TRACTOR (A60430)
JOHN DEERE 6430...
2010 KMC 3376 Peanut Combine (A56438)
2010 KMC 3376...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
32in. Tilt Grading Bucket Mini Excavator Attachment (A59228)
32in. Tilt Grading...
