52farmer
Thinking about updating my TC35D,got it down to these two ,looking for some input
The first question I'd ask is where you're going to find an R4047? I don't think many are left on dealer lots now, but a few could be out there. I sold my R4047H to a member here after 215hrs, but it was a great machine (replaced it with a Case backhoe).
Other than availability, they two are pretty close in most specs for the main machine...the LS weighs about 500lbs more, has a touch more pump flow (not enough to matter much) and one size larger front tires (good if you have wet areas).
The big differences are in the loader, and standard features. The LS loader will lift 900lbs more, but has a lower max lift height (9"). If you don't have to load small dump trucks, or 30yd rolloff dumpsters, the lift height probably won't be an issue, but the higher lift capacity will be a big plus.
As far as standard features, the LS will have a number that cost extra on the Kubota. I have to admit I'm not familiar with all the difference between the L4600 and the new 4701, but I don't think they changed standard features much. The LS will have two standard rear remotes (big plus), telescoping 3pt lift arms and stabilizer bars (huge plus), cruise control, a rear work light, horn, and 7-pin trailer connection (all minor pluses). I don't think the 4701 has a tilt steering wheel, but the LS does, and the standard warranty is longer for the LS, but you can pay for additional for the Kubota to even things out.
I just quickly priced out an L4701 on the Kubota's website, and tried to make it the equivalent to the R4047H, and it came up with a touch over $35K. Figure you'll get something like 15% off of that, so $29K or so. That's about $7K more than R4047s are running (HST).
Other than wanting a bit higher lift height on my R4047, the only other thing I thought that could be better was the opening between the fender well and the brake pedals...a bit more room for your feet to pass through. Some taller folks say they feel a bit cramped, but people here have found a way to move the seat back a couple of inches, which seems to help. I'm not real tall, so it didn't even enter my mind.
Both are good machines, so you really can't go wrong with either. I'd suspect the Kubota to have better resale for at least the foreseeable future, but that could change as more folks find out about LS.
Just added a Kioti DK40SE HST to the mix seems like a well put together tractor,any thoughts. A few less extras than LS but seems like a better tractor
. . . For a bit less money you get a decent increase in PTO horsepower with the LS compared to the Kioti....but that may not matter depending on your uses.
For comparing to the XR4046 and trying to be apples-to-apples, I think you'd have to compare the DK45SE rather than the DK40SE. The build quality would be the same on both, but the DK45 will be a few bucks more than the DK40.
And I agree that it would be hard to make a bad choice between the Kioti and the LS. I could have been happy with either one.
