Kubota L220 snow blower on E Bay now for $5.00
   / Kubota L220 snow blower on E Bay now for $5.00 #1
Junkman
Super Member
North East CT
2003 Kubota BX-22
Not my auction, but someone here might be interested. Auction seller doesn't know what it fits, but the auction starts at $5.00 and it has to be worth that in parts. Does anyone know what tractor this fits?? Located in Moline, IL..... to the auction....
   / Kubota L220 snow blower on E Bay now for $5.00 #2
They appear to be identical to two that I picked up this fall. Had to buy both to get one. Can't remember the model number but they fit on the older L series. Mine bolted right up to my L275 DT and came off a L185. They are a front mount 48" blower that attaches to a framework that is bolted to the front of the tractor and underneath. They are driven off of the crank through an electrical clutch that bolts to the front of the tractor and has a splined shaft that slides over the splined crankshaft. There are 2 belts that go from the electric clutch to a PTO shaft that is mounted on the blower frame. A hydraulic cylinder provides lift. Both of mine included the hydraulic valve assembly and hoses that pluged into my remotes. The chute is turned by a crank handle from the drivers seat. I've got about 10 hours of use out of mine this year and it works well. It will suck up and blow as little as an inch of snow but clogs easily in heavy wet slush. Mine was made in Canada for Kubota but no reference as to who made it in Canada. Only negative is width. Wish it were a foot or ore wider. I am planning on atttaching some 6" wings to both sides of the chute to cover the front wheel tracks.
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A54607)
2007 FREIGHTLINER...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
MISC CABINETS FLOORING (A54757)
MISC CABINETS...
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
