Kubota L2501
   / Kubota L2501 #32
You do realize that the MX is a substantial upgrade in size/weight and a LOT more expensive than the Standard L series tractor, correct?
You don’t typically see an MX compared to an L2501, lol
Mike
   / Kubota L2501 #33
Mike
I sure do love mine though. I never run out of HP and the stability is a noticeable upgrade.
   / Kubota L2501 #34
Things that strain my L2501 are no problem with my MX5200. Only thing that I see as a negative is the DPF on the MX. I needed to pull some wood off a hillside yesterday and regen started. I had to park and wait for the regen to finish because the regen required too much RPM to safely operate on the hillside.
   / Kubota L2501 #35
I’d love to have an MX too! But, might be overkill for my property….well I can think of a couple tasks that I could get done a whole lot quicker and more efficiently with one! Hmmm…
Mike
   / Kubota L2501 #36
I too ran into the same issue recently while running a tiller near a building when a regen wanted to happen. Only maybe the second time of running Grand L’s for over 400 hours so only a minor annoyance.
I didn’t notice the flashing REGEN/Raise RPM’s indicator lights on the console at first. When it hit 103% it started beeping. 😬😳
   / Kubota L2501 #37
Most of my regens seem to happen while I’m grading the road or rotary cutting. I just raise the rpms and keep working.
   / Kubota L2501 #38
I have a gear drive MX. If it were an HST, I could have more easily reduced my ground speed to compensate for the increased RPM and continued operating on the hillside while the regen was in process, but with the gear drive, it seemed more prudent to park and let the regen run its course.
   / Kubota L2501 #39
Makes sense. Mine is HST
   / Kubota L2501 #40
I've used 25 HP CUTs for 40 years around my hilly [30 head] cattle and tree farm. Plenty of power.
70pc. 12ft. x 3ft. White Metal Roof/ Wall Panels (A53424)
70pc. 12ft. x 3ft...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55302)
Galvanized...
2013 Chrysler Town & Country Van (A55758)
2013 Chrysler Town...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
1999 JCB 926 (A53314)
