Kubota L3130 : Gear damaged. Can I still use it?
   / Kubota L3130 : Gear damaged. Can I still use it? #1
hendr1x
2003 Kubota L3130
Hello everyone,
I tore down both front knuckles on my Kubota L3130 (2k hours). Both front bearings were shot. I was amazed how little damage there was. The bottom bevel gear (TD030-13200) sustained almost all the damage. Do you mind taking a look at the picture and telling me what you think? The damage is not very deep and its almost all is on the two teeth you can see. Another two teeth have maybe 25% of what these two teeth have and the rest are perfect.
Also, if you think I should change it, do I have to change the mating gear as well? That one is $350 bucks and I really don't have extra cash around for this so please tell me if its 100% necessary.
Thanks.
Is there a heavy duty bearing people recommend for this location? I know it takes a lot of force.
   / Kubota L3130 : Gear damaged. Can I still use it? #3
edit: brain fart
What does the mating gear teeth look like?
   / Kubota L3130 : Gear damaged. Can I still use it? #4
in an ideal world you would replace both because if one gear is that bad the other will not be far behind. but for a tractor front axle application I would probably not be too worried reusing it if it looks good.
I don't think you can install that bevel gear the other way around to wear out the other side of the teeth.
   / Kubota L3130 : Gear damaged. Can I still use it? #5
Just to clarify my recommendation
definitely replace the small bevel gear in the picture maybe reuse the mating gear depending on what it looks like.
what you see on that second tooth is spalling and will only get worst with time. with 2k hours I think you did good.
   / Kubota L3130 : Gear damaged. Can I still use it? #6
One way only and I'd replace both gears. All you do by replacing one is buy a little time, nothing more. Bite the bullet and do both. Interesting how they wore. I have 6000 hours on one of my Kubota's and had the front left seal replaced by my dealer last year and there was NO wear on the gears at all but then I make sure my axle is always topped off and I use 90 weight GL5 gear oil in the front differential.
   / Kubota L3130 : Gear damaged. Can I still use it? #7
   / Kubota L3130 : Gear damaged. Can I still use it? #8
Not flipped, but oriented (spun?) so the top is now at the bottom. I'm hoping the gear only has splines and not a key so can be oriented in any position, but maybe not.
It still rotates so no matter which wan it's installed, it will at some point, bear on the damaged teeth.
   / Kubota L3130 : Gear damaged. Can I still use it? #9
edit: brain fart
I agree that he should replace them (especially while in there already)
   / Kubota L3130 : Gear damaged. Can I still use it? #10
Is there a possibility of welding to bring the teeth
up to par? I would try a welding shop to see what
they have to say. Cheaper than new gears????
willy
2017 Chevrolet Sonic Sedan (A55758)
2017 Chevrolet...
2005 TerraGator 8104 (A55302)
2005 TerraGator...
2015V Chevrolet Equinox SUV (A53424)
2015V Chevrolet...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
AUCTION STARTS HERE @ 9AM (A52706)
AUCTION STARTS...
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
