Kubota L3300 4 Wheel Drive Service Manual
   / Kubota L3300 4 Wheel Drive Service Manual #1
walton
Milledgeville, Georgia
Ford 1700/kubota 2230
I need a Service Manual for my L 3300. When I engage the 4 wheel drive front axles make a bumping grinding sound and does not pull in 4 wheel drive. Anyone have a similiar problem. The tractor has 1400 hours on it.
   / Kubota L3300 4 Wheel Drive Service Manual #2
Can you put the front axle up so a clearance of couple inches from level area. under the engine is a slide tube covering the propreller shaft to the front end check if a pin is broken in coupling and so disconnected from the front end. if the shaft appears good and still no 4 whl drive possible pinion gear in housing. Check for axle pin wear where the frame to the axle rides should not be able to rock forward or back ward This causes binding in propeller shaft causes breakage. My l3600 never made it to 1500 hours before developing front end problems.
ken
   / Kubota L3300 4 Wheel Drive Service Manual #3
you should get the service manual for this tractor if you are trying to repair this. They are available from dealers or Messick's online.
J.
New Lewis Brothers MFG DB2 Poultry Housekeeper (A48561)
New Lewis Brothers...
Kvernland UN3300 Potato Planter (A47369)
Kvernland UN3300...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A46683)
2004 Sterling...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A45336)
2021 Ver-Mac...
2014 Mack CXU613 T/A Day Cab Truck Tractor (A46683)
2014 Mack CXU613...
2004 GMC C6 FLATBED (A45677)
2004 GMC C6...
