Buying Advice Kubota L3400 HST Tractor Review (9 Years and 506 Hours):
   / Kubota L3400 HST Tractor Review (9 Years and 506 Hours): #11
Very nice write up... the only thing I could add in the way of problems is many of the early ones had suspension seats that were stuck in the down position (easy fix). Last year I noticed my seat suspension broke. (side note: later on when L3700's came out, they did not have suspension seats).
Only other thing I could think of is that some dealers would remove the metal plate that protects the power steering when they mount the brush guard (instead of using longer bolts).
I was lucky with my dealer and got my jerky 3ph replaced with a smooth valve... Have over 650 hours @ 11 years, I never plan to sell it, it's a great little tractor.
2nd edit (seem paragraphs are back again!)
   / Kubota L3400 HST Tractor Review (9 Years and 506 Hours): #12
Great write up. :thumbsup:
Had my L2800 HST just about 7 years just under 500 hours and no complaints other than jerky 3 point hitch.
   / Kubota L3400 HST Tractor Review (9 Years and 506 Hours): #13
In 2007, an L3400 HST with FEL, BB, RFM and Rotary Cutter was purchased for about $21k in Middle Tennessee. The tractor is used on a 50 acre parcel that has been left in timber for about 40 acres. Parcel is hilly, with 300 feet of elevation from lowest to highest points. The attachments are Woods RD7200, BB60, and very heavy 6 Box Blade (Can't remember the brand). It has R4 (Commercial) tires not loaded. 506 hours are on the tractor, and in return for the great advice received from Tractor By Net, I'd like to share a review that might help potential buyers.
What has broken:
1) Peep Window for Hydraulic Oil Level - This was a plastic screw in window that made it easy to check fluid level (Located below the seat on the transmission tunnel). I didn't realize it had broken, until Hydraulic fluid had leaked out. It was an easy fix, dealer had the part on a Saturday morning. The part cost about $25, and $50 for Hydraulic fluid.
2) Hydraulic Return Hose - After my son worked the loader to move creek gravel, I got on and noticed a shudder (Jerking) in the loader operation. Googled the problem, and a lot of L3400 owners posted about it. There's a 90 degree bend in a return line (About the size of a radiator hose), that vibrates a crack on the inside bend. The part cost $35, but was not in stock (Ordered). Install was easy with two hose clamps. Very little Hydraulic fluid leaked out, as this is not a pressurized line.
3) PTO Engage Cable (Shift) - This cable has broken twice. It gets frayed at the top, and eventually will not engage the PTO (Annoying). Evidently, Kubota knows about the problem, and they ship a re-designed shift assembly with the replacement cable. Unfortunately, I was lazy and kept the original shift bracket, so the new cable got frayed and broke again. The cable and new housing ship for about $35 (Parts not in inventory at dealer), so $70 was spent on this issue.
4) PTO Clutches Stick (Biggest Problem) - After about 300 hours, the PTO engage cable could be moved to dis-engage (Off), but the PTO would continue to spin (Dangerous). I googled it (Again), and this is another problem Kubota is known for. Posters say it is due to heat in the clutches (Warping them, so they stick engaged). Fix appears to be expensive, so I've found that if you dis-engage the PTO to off, and drive up to a steep incline (20-25 degrees), then stop and push clutch in, it will usually release (PTO stop spinning). No idea why this works, but it is cheap.
5) HST Rocking Pedal Sensor - At 400 hours, the key was turned, lights came on, but no starter engaged. Charged the battery (Not it). Took the starter off and tested it (Not it). Moved the pedal to center (straight up), and it started right up. Should have Googled it first ($0 cost). There's a sensor on the pedal for safety (I assume).
6) Retractable Seat Belt - Kubota is so proud of these things, I hate to tell them they don't work. Sticks and debris get into the re-coil mechanism, and they stop rewinding. So the belt gets hung over my steering wheel, when I get off. I cleaned out the mechanism one time, but it got blocked in a few days use (No Cost).
7) Tractor Rolled into Creek - OK technically this is not a break, but it was a problem, and since I'm writing the review. It took a come-along snatched to a walnut tree and log chains looped around the ROPS top to bring it up on two wheels and out of the creek bed (Nasty work). No damage. The side fenders, hood and everything were in tact (No bends or dents).
What I'd Do Differently:
1) Load Tires - There have been some really close calls, and I plan to fill the tires this Spring
2) Ag Tires (Possibly) - The R4s wear like iron, and they get traction 99% of the time, but when they break loose on a wet hill side, the ride/slide is not fun.
3) Telescoping Lower Links on 3-Point - The L3400 does not have telescoping links, so changing out the rotary cutter for the box blade requires a 6-foot pry bar to line up the pins.
4) Deeper Cup Holder - The L3400 cup holder is rather shallow, so if you put cigars or a cell phone in it, a low branch or jolt will knock them out onto the ground.
5) Cigarette Lighter for 12 volt access - There's no socket for your air pump or iPhone charger
6) Get Rid Of Cruise Control - Never use it. It sounds good, but I like to be in control.
7) Look Closer at Used Tractors - We got new, because I didn't know much about tractors, and had been told stories of snapped front axles (Due to FEL work). In hindsight, those fears weren't justified, and a good used tractor might have been a better option.
What I'd Do The Same:
1) Get a Tractor - Business folks might say averaging 55 hours of use per year, doesn't justify spending $21k on a tractor. You could pay for mowing ($35 per acre) with the interest on $21k; not counting the diesel and maintenance costs. Good point (But I'd still get the tractor).
2) Get A Kubota - It's had annoying breaks, and I believe John Deere, Case, New Holland, Mahindra and others make fine tractors. I'd probably buy the Kubota again, but I'd consider others.
3) Buy An L3400 - A lot of owners trade their first tractors for larger machines. I would not.
4) No Cab - The ROPS barely fit through low branches, a cab would have been destroyed.
5) Buy From the Same Dealer - My dealer has been great. The salesman explained slip clutches and the value of a rotary cutter (He was right). They've always had my fluids, filters and most parts in stock.
6) Get Advice from Tractor By Net - These folks have been great. The wisdom in this forum is priceless.
Nice comprehensive review. I had none of your problems on my 3400 HST except the jerky 3 point going up. I added an external rear hyd port which was an oem setup from Kubota. Interestingly I think that changed the hydraulic dynamics and the jerkiness seemed to abate.. The rear hyd worked well for the sickle bar mower but I ended up getting an excellent Reece drum mower when I took on a bigger field and this little tractor was too light for that heavy mower. I agree with the loading rear tires. The loader is 72" wide and the tractor width only 49" so it wants to tip over and lift its rear wheels with any full bucket load. I considered adding wheel spacers to increase its stability but a bigger wider Kubota makes more sense. The funky hydraulic fluid window is a lousy idea and hard to see or interpret. A dipstick would be far better.
   / Kubota L3400 HST Tractor Review (9 Years and 506 Hours): #14
I'm glad I went with R1 tires (and filled) when I bought mine new early this year. I wish I would have had the dealer widen the stance of the rear tires before taking delivery.
   / Kubota L3400 HST Tractor Review (9 Years and 506 Hours): #15
I didn't know they were adjustable?
   / Kubota L3400 HST Tractor Review (9 Years and 506 Hours): #16
I just know that the Kubota L3301 rear tires can be adjusted outward another 2 inches total. It's worth asking the dealer before purchasing.
   / Kubota L3400 HST Tractor Review (9 Years and 506 Hours): #17
I'm surprised you didn't have to complain about bent front tie rods if yours ventured ito the woods often enough.
   / Kubota L3400 HST Tractor Review (9 Years and 506 Hours): #18
They are adjustable with the R1 tires; I did mine (L3901), and glad I did. I do not believe you are able to do it with R4's and would need wheel spacers.
2019 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4X4 - 72258 miles -Altec AT40G Boom (A52748)
2019 Ford F550...
2006 BOBCAT S130 SKID STEER (A52576)
2006 BOBCAT S130...
SHREDDER (A52472)
SHREDDER (A52472)
2011 PETERBILT 367 TRI-DRIVE WITH TAG (A52472)
2011 PETERBILT 367...
2004 PETERBILT 379 9 CAR HAULER (A52577)
2004 PETERBILT 379...
(6) Bags of Tire Chains (A51573)
(6) Bags of Tire...
