Kubota L3400 keeps dying
   / Kubota L3400 keeps dying #11
I see this is an old post. So hoping it gets read. Did you ever figure out what the issue is. My l3400 is doing the exact same thing.
   / Kubota L3400 keeps dying #12
I have a kubota L3400 that is 2005 year model and it only runs about 30 seconds then dies. I have changed the fuel filter and had no luck, i have changed the engine fuel solenoid that turns the fuel off if a safety device trips. I can turn the key on and not start the tractor and in about 30 seconds the fuel solenoid clicks and will not allow me to start the tractor, if i turn the key and immediately starts the tractor it will start and run for about 30 seconds. Has anyone experienced this... Thanks
There is a timer relay (usually under the dash) that controls the fuel cutoff solenoid. It is probably failing and needs replaced.
   / Kubota L3400 keeps dying #13
Thank you I will explore that.
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
1996 Elgin Pelican Series S Street Sweeper (A53421)
1996 Elgin Pelican...
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A52705)
2018 CATERPILLAR...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
