bbwithdrawls
Ive had this tractor since late 2004 , no issues , only 320 hours on it , Ipurchased a backhoe ( BH 90 ) in 2008 , used very little , yesterday I was digging water lines about 24 -30'' deep about 170 ft , last 40 ft downhill slope not terribly steep but a slope , all a sudden it starts squealing and I shut it down , as it was 1oo degrees I thought it just got hot , 2 hrs later start it back up digging again , 10 minutes later squealing again and I lost my hydraulics , barley move the bucket or outriggers, call kubota this morning they suspect pump , advise me to get it to level ground and check fluid , I do that , fluid full , but after getting it to level ground I loose my forward and reverse, Glide shift
I suspect hydraulic pump failed then I read on here in another post know issue and service bulletin out on it , sure enough i call kubota dealer and they verify
here's what i found here
"When operating the above units with the front end lower than the rear for extended periods of time it may cause the engine oil to back away from the hydraulic pump gear, causing lack of lubrication. As a result bearing failure may occur. They give this example: Operating the BH90 backhoe with stabilizers fully extended and the front wheel contacting the ground"
Well I certainly did what is described in their example and with the front end down a pretty hard slope to boot.
Kubota has a fix known as a "Holder Kit". What they do is swap the oil filter holder with one that has a connection for a line to the gear housing on the hydralic pump. So they pressure feed that gear with the kit. I need to take a closer look as I'm not sure exactly where it feeds in but I suspect the pump holder assembly which is between the engine block and pump.
I presume Kubota fixed this or put the holder kit on newer models? If anyone has a desire I can post the serial numbers the bulletin applies to. The issue was with L3130, 3430, and 3830 models. If you don't operate nose down for extended periods it's not an issue. The kit is part number TD030-99300
so now I'm a little perturbed , at this point what should I do , I priced a pump and OUCH ! 900 bucks just for the pump , I really feel like kubota should fix it as its a know issues and if its caused by a known issue going downhill that just ridiculous , i realize its not a car but **** sure cost as much ( 28000)
So Ive got my front a side yard dug up and backhoe down , Chinese backhoe out of the question ( shovel ) do i need dealer to verify damage or try and get kubota to fix , I need it yesterday
any advice appreciated , Im not afraid to tackle the pump but tell me if Im missing something obvious here ,
