Kubota L3430 RPM issues.
   / Kubota L3430 RPM issues. #1
RealCodyO
Jacksonville FL
Kubota L3430
At work we have a L3430 Kubota tractor. A few months back the tractor was struggling with RPM, the RPM would be steady to wherever I would set them then they would drop to almost zero then recover. Occasionally the tractor would stall all the way out. This occurred in L, M, and H. We sent the tractor off to the Kubota dealership and they replaced all fluids and said everything was fine except the clutch was looking rough and my headlight display was busted. It's been about a month since and the tractor has run perfectly but last week the RPM issue started over. Also when the RPM messes up the tractor almost smells like it's burning something, more so than the usual diesel smell. Any idea guys? :confused:
   / Kubota L3430 RPM issues. #2
Loss of power comes down to one of 3 things: fuel, air or spark (and in diesels there is no spark..). If the air filters are good and there are no air leaks in the intake system, I would look at fuel delivery. Sorry I can't be more specific, but that is the gist of engine troubleshooting... Try checking for air leaks first.
   / Kubota L3430 RPM issues. #3
The last tractor I dealt with that had these symptoms ended up having a bunch of junk in the bottom of the fuel tank. It would idle down to about half it's normal idle speed regardless of throttle setting for a while then slowly recover, run fine for 5-10 minutes and repeat.
Ended up using a short piece of water hose duct taped to a shop vac to suck the bottom of the tank clean. There was grass, dirt and who knows what else in there. How that much crud ever entered the tank is beyond me, my guess is someone ran it without the fuel cap.
Good luck.
Thanks all. Guess my best option is to drain my fuel tank.
UPDATE: Drained the tank and inside I found a flex nozzle that you would find on the end of a 5gallon gas can. Someone must have dropped it in there and decided to not worry about it. Now time to figure out how to get it out without removing the fuel tank.
   / Kubota L3430 RPM issues. #6
One of the claw extractors should be able to grab it. Here is an example. They can be found at auto parts stores.
Sears.com
Beautiful, I like that plan. Will post update Wednesday.
   / Kubota L3430 RPM issues. #8
Please do, happened to me last year, (spout fell in), no issues yet,
but would like to get it out.
UPDATE: Sorry for the late reply, work has been a rainy mess. I bought one of the claw extractors from ACE for around $4 and removed the old flex hose. I then put in 5 gallons of fresh diesel and the tractor is running like a dream. Thanks all for the tips, glad it was an easy fix.
   / Kubota L3430 RPM issues. #10
That's good it was a easy fix.
2008 INTERNATIONAL 9200I DAYCAB (INOPERABLE) (A48992)
2008 INTERNATIONAL...
SWEEPER (A48992)
SWEEPER (A48992)
2011 Ford Escape XLT SUV (A48082)
2011 Ford Escape...
2007 CHEVROLET KODIAK C6500 (INOPERABLE) (A48992)
2007 CHEVROLET...
2013 VOLVO VNL860 TANDEM AXLE SLEEPER (A45679)
2013 VOLVO VNL860...
TUTHILL BLOWER (A48992)
TUTHILL BLOWER...
