Kubota L3550 tranny problems
   / Kubota L3550 tranny problems
I am pretty sure it is the shift fork lever but I can't work on it right now thanks for the help but I am open to new ideas.
i kinda hacked it but i got it to shift again and every now and then it wont but there has to be something i am missing.
   / Kubota L3550 tranny problems #13
When you pull the shift cover off you will see a roll pin holding shift arm to the shaft it is either held in with a cir-clip or a wire running through the center of it. That roll pin is broken. Kubota makes a solid pin for this, or you line the holes up, open the hole up with a 1/4" drill bit, get a piece of drill rod and make your own pin and cut your own snap-ring groove in the arm and put it back together. Or for the quick repair drive out to out roll pin and drive in a new 6mm roll pin and know that you'll be doing it again at some point.
Brian
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
1977 Ford F100 (A53422)
1977 Ford F100...
2012 Freightliner M2 Chipper Truck (A52377)
2012 Freightliner...
2020 Brenner 450 Gallon Skid Mounted Vacuum Tank (A52377)
2020 Brenner 450...
