Kubota L3940 HST won't go into reverse
   / Kubota L3940 HST won't go into reverse #1
GunChuck01
New Virginia, Iowa, USA
Kubota L3940
I have a Kubota L3940 with hydrostatic transmission.
The tractor has stopped going into reverse when activated by the pedal.
It stopped working when I was driving thru some brush, so I thought a branch may have become wedged in the reversing mechanism. However, no branch and no visible evidence that anything is bent or broken.
The mechanism under the pedal is gold/brass colored and appears to have a pin on one side that may go into a hole on a cam on the other side and there are some springs on the cam.
I have looked for, but not found, a picture or diagram of how these items are supposed to work together.
Anyone have any diagrams or explanation of how this is supposed to work or any tips how to fix ?
   / Kubota L3940 HST won't go into reverse #3
Usually this NO REVERSE is caused by brush pulling electrical wire loose from reverse solenoid.
This happen to me twice, then I armored underneath with heavy expanded metal.
Where is wire for reverse solenoid connector ? Have looked but cannot find .
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A56129)
2020 KENWORTH T680...
2005 INGERSOLL RAND SD-70D TF SMOOTH DRUM ROLLER (A52706)
2005 INGERSOLL...
19088 (A55758)
19088 (A55758)
2020 Ford F-150 Crew Cab Pickup Truck (A53422)
2020 Ford F-150...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
