Kubota L4610 Power Beyond port
   / Kubota L4610 Power Beyond port #1
jedens
La Veta, CO
Kubota 4610
I've lost my manual for my tractor. I want to get a hydraulic port selector to put on my power beyond port. Is that port a 1/2" or 3/4" port? Thanks for the help!
   / Kubota L4610 Power Beyond port #2
</font><font color="blue" class="small">( I've lost my manual for my tractor. I want to get a hydraulic port selector to put on my power beyond port. Is that port a 1/2" or 3/4" port? Thanks for the help! )</font>
Unsure of what you are trying to do. Power beyond typically feeds the pump
port of a downstream valve in a static configuration.
If it is a Husco series 5000 sectional valve the power beyond port is either
SAE10 or SAE12 ORB depending on whatever option Kubota chose.
   / Kubota L4610 Power Beyond port #3
On a 3710 it's a Husco valve- power beyond port is 1/2" it takes a straight thread o-ring type fitting
Also note that hydraulic circut can be taped at rear right side of case- you will see a triangle shape cover block-this is where the kubota remotes bolt on- on gearmore top and tilt kit they just made a alluminum block drilled for oil passage and fittings and bolt it on where the triangle block was, return is connected to a nearby hole that has a rubber plug in it
PALLET OF SCAFFOLDING (APPROX. 19 PC) (A52706)
PALLET OF...
30007 (A53424)
30007 (A53424)
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
SKID STEER GRAPPLE (A53843)
SKID STEER GRAPPLE...
2015 TROXELL 130BBL VACUUM TRAILER (A53843)
2015 TROXELL...
