Kubota L6060 HST Creep
   / Kubota L6060 HST Creep #11
So today I did the same test in the same place and the creep was minimal. When facing downhill the creep was almost negligible and when facing uphill it was noticeable but slower than yesterday. That was with the tractor in high range (turtle) in mid range the creep was almost zero facing downhill and very little facing uphill. I suspect the way it was working today is normal and will keep an eye on this over the next uses to see if there are any changes.
Confused here.
High range is rabbit. Low range is turtle.
SDT
Confused here.
SDT
My L6060 has HDS with each range having a rabbit and turtle mode by using a shift lever on the steering column. I absolutely love it and use it a lot. It effectively gives the tractor 6 ranges and the HDS can be used on the fly, which is great.
   / Kubota L6060 HST Creep #13
If there is creep start looking at the linkage adjustments.
   / Kubota L6060 HST Creep #14
Same as mine.
SDT
Same as mine.
SDT
But you said you were confused. Now I'm confused. Maybe I didn't explain well enough. When I noted I was in High range (turtle) I meant the tractor was in high range with the HDS set at turtle (ie the slower HDS speed in High range). The Intellipanel shows either a turtle or rabbit for each of the three main gearshift ranges.
40' CONTAINER (A51244)
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
2008 New Holland B110 MFWD Loader Backhoe (A52748)
2008 New Holland...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
