SDT
Veteran Member
Soon I will be buying a large hydrostat CUT to replace my 44 PTO HP MF 533. The tractor will be used as my "first round" tractor to pull a heavy Woods BB720X 6' cutter.
I spend a great deal of time cutting in my various irregular, some steep, parcels due to continual reversing to back beneath trees and other obstacles. A hydrostat is ideal for this task. Once the parcels are cut in with a "Cadillac round" or two, I switch off to one of my bigger tractor/mower combinations to finish up. Because I spend more time making the first round or two than mowing the remainder of some parcels, a hydrostat "first round" tractor/mower will save considerable time. Due to trees and other obstacles I must use a ROPS tractor as a cab would be too susceptable to damage.
I have investigated the Kubota L6060 and, to a lesser extent, the comparable JD 4066R.
I like the ePTO offered on the JD (not available on the Kubota), though I do not know how often I will be able to use it as I am often in heavy stuff using over 40 HP. I also very much like the rear fender mounted creep and lift controls (again not available on the Kubota) very helpful when hitching implements. Though the JD engine is smaller displacement, it is intercooled and produces rated HP ar 200 RPM less than the Kubota. PTO HP is nearly identical. I'm old school and like engines that operate at lower RPM. Indeed, this is my most liked feature of my MF 533 (2007 version of the 135). The 3 cylinder, long stroke, underrated, normally aspirated, 202 CI, Perkins engine produces rated 44 PTO HP at 2,200 RPM and PTO speed is about 1,750 RPM. The torque rise is phenominal and it also sips fuel. Aside from the much liked engine, the 533 is very basic, e.g., 4X2 crash box, 2WD, dry drum brakes, etc.
On the other hand the tire selection of the JD leaves much to be desired. R4 tires, which I would specify, for this tractor, are only available with one piece, non adjustable rims. In order to get bolt together 2 piece rims, one must order R2 tires, which would be acceptable to me if they were larger. The only AG tire selection is 13.6X28/8X16, which is simply too small for a 50 PTO HP tractor. They are also 4 ply rated, which is inadequate. The Kubota is available with 14.9X26 6 ply rated R2 tires or R4 tires, either on bolt together, adjustable rims. I DO NOT like one piece rear rims.
Other features of the tractors are similar though the Kubota is a bit heavier and has a more sophisticated hydrostatic transmission.
Either tractor would be bought with a non self leveling FEL with third function valve, two rear remotes (2 levers, 4 couplings), 2 rear weights per side (no liquid ballast, as I change my own tires) and a full set of front weights.
I have a good relationship with my local CNH/Kubota dealer, which is only 5 miles away, though they are not known for selling at the best pice. Indeed, I just bought a Kubota M9960HSD12 ROPS (delivered the day before yesterday) to replace one of my other, larger finishing-up tractor. I have no experience with any of the local JD dealers, which are all between 20 - 30 miles distant, so I would be rolling the dealer dice. I rolled the dice when I bought my 2 MF tractors and lost.
Anyone have anything to offer regarding the Kubota L6060/JD4066R comparison?
Thanks, in advance.
SDT
Thanks, in advance.
SDT
