Kubota LA211 - Hydraulic Fitting Leak
   / Kubota LA211 - Hydraulic Fitting Leak
Everyone, I would probably feel like an idiot after taking the cylinder off and taking it to a company to get it fixed. I say this based on the information I got here as well as from Kubota. I was told the fitting could be unscrewed and replaced to it was welded and could not be serviced, resulting in having to buy a new cylinder. Even Kubota said it was not serviceable.
Well let me tell you what the truth is; referring to the attached photo. The fitting is indeed welded into the cylinder. However, there is a screw on fitting (silver color in pic). When you remove this screw, you will find an o-ring. Mine was bad which caused the leak. Hopefully, this will help someone having the same problem.
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
LMC G300JD LOT NUMBER 246 (A53084)
LMC G300JD LOT...
JOHN DEERE R4023 LOT NUMBER 261 (A53084)
JOHN DEERE R4023...
Golf Cart (A51694)
Golf Cart (A51694)
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
