Kubota LA351 valve block
   / Kubota LA351 valve block #12
isn't that the same valve as posted above? i don't see where the 3rd hose goes. what does the 3rd hose do anyway? any help is appreciated.
thanks
   / Kubota LA351 valve block #13
You have 3 hoses to the tractor. One is high pressure coming from the pump, another is the high pressure return from the power beyond which feeds the 3 point lift. The final is the lower pressure return for the oil used by the valve.
   / Kubota LA351 valve block #15
thanks. that explains a lot.
so that means i need the power beyond kit as well right?
do any of you know which is which on my original valve? i have 2 that look like they come from close to the engine (i assume this is where the hydraulic pump is), and one the goes to the back of the tractor to i guess that's either the tank or the 3pt. will it kill anything if i hook it up wrong while trying to figure out what goes where?
thanks again for all the help, i've almost got it all figured out.
   / Kubota LA351 valve block #16
Yes, you wll need the kit or adapter.
If the PB port has a plug in it now, you will need the adapter sleeve or the hex screw to make that port a PB port.
After you install the PB adapter, connect a hose from the PB outlet to the 3pt line, and route the tank port to tank.
   / Kubota LA351 valve block #17
thanks, i got it.
i just got back from the kubota dealer, and they told me which line is which. so now all i have to do is buy the valve, buy the adapter, buy 3 new hoses the right length with the right fittings, weld up a 90 deg plate to mount the new valve on, and jerry rig an adapter for my old control lever. no problem.:thumbsup:
thanks again for your help.
2005 Chevrolet C4500 Landscape Dump Truck (A56858)
2005 Chevrolet...
LOT: Assorted Hammers (A59076)
LOT: Assorted...
UNUSED FUTURE 72PRO 72" HYD MULCHER (A58376)
UNUSED FUTURE...
2025 Starvox SV-480 23HP Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple... (A59225)
2025 Starvox...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56438)
2020 Westfield MKX...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
