Kubota loader bucket not level?
   / Kubota loader bucket not level? #11
If your bucket is low on the left side,,, next time you try to dig up something hard, use the right corner of the bucket. If it's off the other direction, reverse procedures. If you use your FEL hard, you'll see this a lot... :rolleyes:
   / Kubota loader bucket not level? #12
Thanks....ovrszd.....that's worth a try....that is, not too hard to do but I'll be easy on the stick.
   / Kubota loader bucket not level? #13
I try to use the center of the bucket, rather than a corner, minimizes this problem. Understand, your FEL has the lift capacity to bow the bottom of the bucket as well as twist it's frame if used improperly.
Very common to hear guys talking about their bucket not sitting flat on the floor when lowered. :)
   / Kubota loader bucket not level? #14
I agree with everything you said, but as I understand it the OP's tractor is new.
Yes it's new! Under 7 hours and have not moved any dirt or rocks yet, just pushed snow.
   / Kubota loader bucket not level? #16
And if you chose to drop it off at the dealer for adjustment, after you drive off, the mechanic will hook one corner of the bucket under something and tweek it back straight.
   / Kubota loader bucket not level? #17
When you check the pressure make sure you have the tire valve at 12 o'clock if the tires are loaded.
   / Kubota loader bucket not level? #18
One other thought, put the bucket flat on the ground and lift the front end and see if the bucket is level or if the tractor is unlevel. I am thinking there might be just enough play in all the joints to make the bucket seem off level without weight on it.
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
1994 EZ-GO Golf Cart (A56859)
1994 EZ-GO Golf...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2022 ALLMAND LIGHT TOWER(INOPERABLE) (A58216)
2022 ALLMAND LIGHT...
Caterpillar T30B Warehouse Forklift (A57148)
Caterpillar T30B...
