Kubota loader control
/ Kubota loader control #1
NewfieDan
Eastern, NL
Kubota BX2360
On my Kubota 2360 the loader control seems to have a problem. It seems that either the loader control lever has either moved or there is something bent somehow. When the lever is moved to the right to curl up the bucket, it hits the throttle lever. This new and has never happened before. I am wondering if there may be something bent under the cover or of something has loosened up allowing the lever to shift somehow?
Has anyone else had this issue?
/ Kubota loader control #2
Does the lever feel loose like it is turning? Can you take the cover off and look?
/ Kubota loader control #3
Haven't seen this but there must be an issue with it! Is it moving further then before?
/ Kubota loader control #4
Check to make sure that no bolts have come loose and slipped out...it's possible that looped etc. hoses could be pushing the valve if a bolt has come out...?
/ Kubota loader control #5
..and show us a pic of what you find please.
Fixed this problem today. Started by removing the single bolt that holds the plastic cover in place. It is at the front of the cover next to the hood.
Removed the 2 nuts holding the control lever in place. Found that there is a connecting rod that goes from the control lever to a point just under the dash. This connecting rid had worked loose. Re-adjusted to where it is supposed to be. It is a little finicky to get it just right, without being too close or too far out. Put everything back to double check the spacing, tightened everything back up. Put the cover back on.
Took a total of about 20min to do. Most of that was trying to get the adjustment in just the right position.
/ Kubota loader control #8
I wonder if it would be worth putting some Loctite on the rod, especially if it loosens again.
Jim,
I thought about it. But there is lock nuts to hold it, and the end under the dash is little awkward to reach. Even with a lower tack loo title there might be issues trying to do anything with it later.
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
2008 Toro Multi Pro 1200 Turf Sprayer (A61572)
2008 Toro Multi...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
1993 CHEVROLET Corvette (A59231)
1993 CHEVROLET...
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
2016 John Deer 5075E (A60462)
2016 John Deer...
