Kubota M108s or JD 5115ML
   / Kubota M108s or JD 5115ML
I sorry but I don't know much about clamp on duels... I'm not a farmer mainly a groundskeeper on an estate.. could you send me a link or two to get me started in looking at them and what you would recommend for my NH Powerstar T4.75? Appreciate it much....
   / Kubota M108s or JD 5115ML #12
For a manicured lawn on a steep slope I would stick with the Ventrac. If you need to mow it faster get a second Ventrac and a second operator.
Sometimes it is better to have two mowers instead of one larger one, that seems to be the case in your work.
I actually have 2 Ventrac's; a 2012 4200 vxd 26.5 diesel and a 4500p 31 hp Kawasaki gas. I did have a second operator then another one and another. It seems people want $ but don't want to work for it. Showing up to work on time is a good start. Always having personal issues interfering is another and so on. I found myself 1/2 the time doing it myself anyways. Eliminating that part of the frustration and making it so I am independent to me is a big plus. Your idea is great... just need to find the right person who is responsible. Do I want to keep hiring and dealing with bs until I find that person? or look for a tractor that works.... I might just have to bite the bullet and get an EABI http://www.aebi-schmidt.com/en/products/terratrac or equivalent. By the way I see you have a x749.. this past summer I picked up a x739. Love it.... There is tons of landscaping around the property, scalloped and tight turns and the AWS with AWD is awesome..the Ventrac's can't maneuver as well in these tight areas like the x739. I wish they did it with a diesel instead of gas motor tho but I guess JD discontinued that model.... This is my lineup...I start with the x739 doing all the small areas especially around the landscaping which is all over the place by the main house then get on a Ventrac do all the slopes and 2-3 passes along the perimeter of the whole property then hop in the NH with the batwing and finish banging out all the rest. how do you like your x749?
   / Kubota M108s or JD 5115ML #14
I am well pleased with the x749, good for mowing and lawn maintenance jobs. Climbs steep hills very well and is cheap on fuel. Use it with an IMatch and attachments where I want to keep off of manicured lawn areas. I often switch between my backhoe, tractor and mower and like the fact that all three have the same hydro pedal configuration. The rear 540 pto works well with a small chipper, spin spreader and 4' tiller. The most usedl implements are the pine needle rake and lpgs. Good for smoothing and cleanup tasks as well as mowing.
2011 John Deere Gator Utility Cart (A55973)
2011 John Deere...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
1998 6X12 Utility Trailer (A56859)
1998 6X12 Utility...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
Bobcat T590 (A53317)
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
