OP
TRM 1
- Joined
- Mar 3, 2012
- Messages
- 11
- Location
- Rocky Mount, VA. 24151
- Tractor
- Kubota M4900, Kubota M9000, Kubota M4030SU, Massey Ferguson 393
The remote valve actually bolts to the side of the housing and is fed from the housing itself. So it really doesn't have any hoses feeding it. It has ports (I assume) that feed the valve. We also have a M4030 with a Bush Hog loader on it that is fed from the remote valve and when you want to use the loader you lock the remote valve in position to feed fluid through the remote to the front end loader. When the valve is locked in place like that the 3 point hitch doesn't work although it does stay up and doesn't drop. When you want to use the 3 point hitch on that tractor you put the remote valve in the neutral position and the lift works then. So I would think the m4900 would be the same as far as using one or the other at a time although the lift shouldn't drop down when you use the remote valve.
