kubota M5-111 fuel not getting to the rail
   / kubota M5-111 fuel not getting to the rail #1
Bmbcattle03
Kubota m5-111
tractor cranks but no start the electric fuel pump keeps pumping no matter how long you leave key on. fuel getting to the supply pump but not to the rail it seems to keep going threw the return back to the tank
   / kubota M5-111 fuel not getting to the rail #2
Looking at the specs it looks like a common rail system. I assume the injectors fire electronically. I’d start by looking for wiring problems, mice damage etc. I assume the fuel filters are good?
   / kubota M5-111 fuel not getting to the rail #3
Most cr systems I’ve worked on have an overflow banjo bolt in the end of the rail..
It holds pressure in the rail and opens when there’s to much..
U might wanna look for it..
If the supply pump is pumping to the rail and it’s returning.. the spring might be broken or the ball valve stuck open.??
Bus (A50323)
Bus (A50323)
2018 John Deere R4038 Self Propelled Sprayer, (A50657)
2018 John Deere...
2015 MACK GU713(INOPERABLE) (A50854)
2015 MACK...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A51222)
2019 TOYOTA...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A51039)
2016 KBH...
