Seven Gables
Platinum Member
- Joined
- Jan 30, 2019
- Messages
- 607
- Location
- Northern lower Michigan
- Tractor
- jd 5115m , Ford 545D, Kubota M8540, NH t4.105 , Ford 5030, Ford 4830, NH TN 95FA, Volvo EC60E
I have a M8540 that I had the same issue with trying to engage a Rears brush grinder, like a flail mower but about 3 times as heavy, will grind up to 4" diameter wood/ brush. At idle or a little above would stall the engine when I engaged the electro engagement knob, which I'm pretty sure is what you have. The manual lever type that some of my other tractors have you would just feather in no problem. The good news is you can feather the electronic engaged kubotas , just turn the knob on off on off on off while watching the pto shaft it will begin to rotate slowly, once it gets going just leave on. With a little practice it's very easy. Kinda an oversight on Kubotas engineering. B
