Kubota Mechanical Advice
   / Kubota Mechanical Advice #1
Pks
Platinum Member
Saline, Michigan
Kubota L3700SU, Cub Cadet 1430, Hustler Super-Z 66in, Vermeer 1250
I am looking for a mechanic familiar with repairing Kubota hydraulic transmissions.
Here's what I have:
My B2400HD hydraulic transmission began leaking badly during usage. It leaked up under the frame rail along side of the pump/motor housing (at the cast iron valve body). I can't determine visually any better location than that. The transmission does not show any symptoms of a mechanical failure other than it leaks oil (about 1 pint per hour during use).
I have removed all the hydraulic pipes and lever linkages in order to split the transmission from the center frame. When I removed the suction strainer, there were metal shavings and a broken o-ring (about 3/8" diameter). The o-ring felt brittle when I played with it.
Where could this o-ring have come from and could it be part of the cause that something has broken?
Thanks, Peter
   / Kubota Mechanical Advice #2
How much shavings did you have in the suction screen? It may be a
normal amount, esp if the screen has never been cleaned.
As for the missing O-ring, that is a good bet as to the cause of your
leak. More likely from the implement pump circuit vs. the hydrostatic
transmission, IMO. I do not know your tractor, but I have seen O-rings
used for some kinds of hydraulic connections, like between valves and
the sump, and with manifolds like you use to connect a loader.
For HST plumbing, the lines I see are usually hardlines with compression
fittings, or banjo fittings. No O-rings.
Some tractors use lots of O-ring face-seal fittings for the implement
pump circuit, (e.g. Deeres), but I don't think your B does.
There wasn't much in the way of shavings on the screen...just more than at the 300 hr maint interval. The o-ring is what surprised me. Due to the configuration of The transmission motor and pump assembly is one big chunk. So the o-ring must have come from inside. There is a separate implement pump & circuit but iit hangs off the side of the engine. The hydro-trans and pump assembly is under the seat and attached to the rear axel housing.
I suspect the o-ring came from the piston pump or piston motor which drives the axles.
   / Kubota Mechanical Advice #4
Any O-ring in the system could be washed downstream into the sump.
Check the implement pump's hardlines. If they have flanges, they use
O-rings. If you have a loader, there is a manifold that connects to
the main tractor casting, and it uses O-rings. FEL valves may use O-rings,
too, but I do not think that is your source since your FEL valve is mounted
to the loader mast.
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56438)
2020 Westfield MKX...
207276 (A52708)
207276 (A52708)
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
JOHN DEERE 470G LC EXCAVATOR (A60429)
JOHN DEERE 470G LC...
