Kubota MX500 Loader Not Lifting Unless Remote Engaged
   / Kubota MX500 Loader Not Lifting Unless Remote Engaged
Thanks Leejohn, that was it.
On the front hydraulic block there between two of the connections there was a flat head screw that had somehow got turned. It seems to lock out the flow from the loader - I assume so you can get greater flow to the remotes.
Anyway, we just adjusted it and all is well now.
I really appreciate the support, it was a real puzzler and although it wasted a few hours of troubleshooting, it was a simple fix and saved us an expensive and time consuming trip to the dealer.
   / Kubota MX500 Loader Not Lifting Unless Remote Engaged #12
Well great it's always good to save money!!!!!
   / Kubota MX500 Loader Not Lifting Unless Remote Engaged #13
Rawkis check the hyd. outlet block there might be a spool with a screw drive slot that you turn it for other hyd attachments. It might of got turned for some reason.
This little piece of advice! Just made my day! I have been having the same issue with my Kubota loader and was fearing a much worse scenario. You gotta love just turning a little screw and solving all your problems! Its taken me numerous hours of searching and finally found this tidbit of info. Thank you!!
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A53421)
2018 JCB Truss Jib...
2021 Ford F-600 4x4 Mechanics Service Truck (A55852)
2021 Ford F-600...
2004 Sterling Acterra Cab and Chassis S/A Truck (A55852)
2004 Sterling...
