Kubota Relief valve shim?
   / Kubota Relief valve shim? #11
Wether you will notice a difference or not depends on what you do.
IF you are just moving loose material and dirt, and have no issues with a full bucket, then you wont notice. But if you are having issues, or lifting heavy things with a boom pole or pallet forks, then you will notice.
Why not call your dealer before you do anything. 1. You dont want to void your warranty. And 2. If the pressure is below spec, they should make it @ spec for you at no charge if you are having issues.
How much fluid should i prepare to catch when i pull off the spring cap and is the cap going to have spring tension pushing against it?
Thanks LD1 I may give them a call but I already modified the hydro system with a diverter and rear remotes so they might already want to look down there nose at me.lol
nothing like being a procrastinator.lol
Finally shimmed my relief valve, had 1.7 mm of shims and i swapped arround some washers and ended up with a stack of 2.3 mm and gained 250 lb so the 40 lb per mm is a pretty close estimate.
   / Kubota Relief valve shim? #14
Wow, I'v thought I was bad at putting stuff off...
Oh wait, I still haven't done mine, so I guess, I'm worse than you.
Congrats,
Thomas
Thomas,
It was super simple , I did remove the tire for easier access and had to tweak the one hard line just a bit to get the socket on the relief valve nut.
Lost maybe a couple ounces of fluid and was able to find a couple washers in my cabinet that were the right dia (#10 stainless). factory had three shims of different thickness's ,used metric measurements on my dial caliper because I read somewhere that 1mm = 40 psi.
Commercial Truck Frame with Axle (A55852)
Commercial Truck...
22ft Rollback Flatbed Body with Winch (A51692)
22ft Rollback...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
Kubota BX2230D (A47384)
Kubota BX2230D...
