Kubota Specs???
   / Kubota Specs??? #11
So just wondering, how many hours are on the machine now??
   / Kubota Specs??? #12
I know that you are upset, but this is a question that should have been asked and answered BEFORE the purchase. When it comes the hydraulic attachments, especially mulchers, you always have to match the attachment's motor to the flow coming out of your machine. Whether the machine was standard flow or high flow, the dealer should've been able to tell you what GPM's are coming out of the machine and then put the appropriate attachment on it. If you said you wanted high flow, then when the dealer ordered the machine he should've either added the high flow or it comes standard. To me it sounds like the dealer needs to get his act together and know his product better.
   / Kubota Specs??? #13
Hello to all.....I own (2) SVL-90's and both have High Flow. I run a multitude of Hi-flow attachments including a new Loftness G-3 Mulcher.
If you hold down your flow switch on the downside for 5 seconds you will be in Hi-flow, 36.5 gpm and it will show on your display...
I can't believe the dealer didn't show you.....
   / Kubota Specs??? #14
Call me and I can talk you through how to get it in Hi-Flow.......248-939-3986. It's a great machine. I switched from ASV's
Hey, just wanted to get your guys thoughts on this. I purchased a Kubota SVL 90 a couple months ago. One of the main uses I have for it is mowing and mulching, so I wanted high flow and that's the main reason I went with the 90 and not the 75. It wasn't till the last second that I chose to go with the Track Loader, I was checking out a bunch of the L and M series tractors, and going through all the specs with a fine tooth comb. As I went through the PDF specs on the L and M series, there would be certian specs that were labeled as (option). So when I changed my mind and started looking at the SVL 75/90 specs I saw nothing listed as option and everything I read about the SVL 90 seemed to suggest that it was high flow, including the owners manual, in no place I read that it was a option. So $85,000 later with a new tractor and a new mulcher, I go to put it in highflow and realize I don't have it...:mad:
Just want to get your guys opinion and hope you could spend a minute checking out what I'm talking about. The machine works fine, but highflow would make a significant difference in mulching operation. I asked my dealer about it, and he kind of agreed with me but acted like there was nothing I could do. On that note he did offer me options and never mentioned highflow when we talked about that.
Thanks in advance!
golf cart (A56859)
golf cart (A56859)
CAT 930M (A58214)
CAT 930M (A58214)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
Wolverine Quick Attach Skidsteer Grapple Bucket (A59814)
Wolverine Quick...
