Kubota super UDT fluid?
   / Kubota super UDT fluid? #1
irishl
ocala, florida
I have a b7500dt is it a must to use this type of transmission oil or can I use a universal transmission oil found at tractor supply? Or, is this more for hst transmissions? Please let me know if it makes a huge difference in performance of the tractor.
thanks irishl
   / Kubota super UDT fluid? #4
I agree with FL. The cost savings is not that much and you know you do not have to worry about your warranty etc.
   / Kubota super UDT fluid? #5
Its all fine as long as it states that it meets Kubota UDT. I would not worry about it one bit. I have not seen any difference in UDT, Super UDT and other products, namely, Chevron All Weather Synthetic Hydraulic Fluid. I also live in a mild climate and would no doubt find the synthetics more advantageous in cold enviroments.
   / Kubota super UDT fluid? #6
I agree. If it states it meets or exceeds Kubota UDT, you are fine.
Super UDT from what I was told has a lower pour, shear stable, more friction mods (adds) and can be used in more then diffs etc.
But of you look online at Kubota's stite they state:
"Transmission Oil (KUBOTA SUPER UDT *1):
(I bolded some areas)
KUBOTA Original Transmission hydraulic fluid. The oil used to lubricate the transmission is also used as hydraulic fluid. To insure proper operation of the hydraulic system and complete lubrication of the transmission, it is important that a multi-grade transmission fluid be used in this system. We recommend the use of KUBOTA UDT or SUPER UDT fluid for optimum protection and performance. (Consult your KUBOTA dealer for further detail.)
Do not mix different brands together. "
From what I read and printed awhile ago, The recommending of both is new.
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
2013 FORD F150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F150 XL...
20ft. Deer Gate (A55758)
20ft. Deer Gate...
2014 CATERPILLAR 826G LANDFILL COMPACTOR (A51406)
2014 CATERPILLAR...
