Kubota won't go in reverse
   / Kubota won't go in reverse #1
amazincaucasian
mo
2013 Kubota kx-121, 1988 Kubota L2202DT 1998, Bobcat 331 bobcat, F800 dump truck
My old Kubota (1988) just grinds when I try to put it in reverse. It's not a hst just manual. I had a skidteer push me up a hill while I drove in low gear and I guess something got jammed or hung. Maybe I was being pushed faster than I was driving. This happened before when I roll-started it down a hill and accidentally had it in reverse instead of. 4th. Somebody told me drive it in high 3 or 4 miles and it will unbind but no results.Also sometimes when it's put in reverse it jumps forward. Any suggestions?
   / Kubota won't go in reverse #2
Please post what model. There were many models in 1988.
Thank You,
Brian
   / Kubota won't go in reverse #3
If the clutch is operating properly think about taking the top off of the gearbox and checking out the internals.:D
   / Kubota won't go in reverse #4
:confused: Never heard of anything like that before! It won't hurt it for sure, but don't see how that could possibly "unbind" the drivetrain.....
Thanks for the replies! It's a L2202DT grey market tractor. Which I am expecting to be very very aggravating to find parts for. Since my post, I took it to the tractor shop because I really need it for a job and he looked in and says the reverse synchronizer is broken. So does anyone know where I can find a reverse synchronizer for it? Thanks again!
   / Kubota won't go in reverse #6
Might try posting down in the grey market tractor forum for help with parts etc.
   / Kubota won't go in reverse #7
sounds like clutch disk is stuck try bumping the tractor against something like a tree or stump to see if you can free the disk up
MASSAGE CHAIR (A58214)
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
case 370 glass door never installed (A56438)
case 370 glass...
JLG 600AJ SKYPOWER TELESCOPIC BOOM LIFT (A60429)
JLG 600AJ SKYPOWER...
Wolverine Quick Attach Screening Bucket (A59814)
Wolverine Quick...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
