Kubota ZD 1511 performance
   / Kubota ZD 1511 performance #12
Do you ever do this hill left to right?
Thanks
I haven't ever mowed it left to right, but it wouldn't be a problem at all since I've fluid filled my rear tires.
I couldn't mow it over towards right side if grass was wet tho.
   / Kubota ZD 1511 performance #13
IDK what degree it is.
I've got an angle finder gadget I used on my 4wd truck driveshaft once :
I'll try to find out for you.
   / Kubota ZD 1511 performance #14
I have a zx726 now and it is awesome on hills. It’s gas and only a 60” in cut and I like others have a diesel tank onsite and am growing tired of the gas can business lol.
Thanks for the info.
   / Kubota ZD 1511 performance #15
Coming off a 4wd tractor & 110" RFM : I was very disappointed in the lack of traction with this Zero on my steep hills & especially getting stuck weekly in mud.
Fluid filled Rears along with Experience has really helped me a LOT, BUT loosing 38" each Swath doesn't save me any time mowing 3hrs x 3 days a week.
I'm not DIRTY (thanks to RD deck) & not tired after getting off my ZD1211 & the cut is far better than my RFM, plus I can trim so much closer to trees & fences.
Plus the Zero saves me 10Gals of fuel each week :D
   / Kubota ZD 1511 performance #16
I took the turfs off my grasshopper and put bar tires on. The traction is significantly better. IMG_4309.JPG
   / Kubota ZD 1511 performance #17
   / Kubota ZD 1511 performance #19
How is the ride vs the turf tires.
Are they a stiffer tire ?
Do you notice much difference in ride comfort ?
I originally wanted tractor tires because they probably would have been stiff enough to run without air. Those tires are about the same stiffness as a turf. IMG_4414.JPG
   / Kubota ZD 1511 performance #20
Do you know how many degrees it is? ...
The Left side of my pic where your red circle is 15-20degrees.
The Right side where I stopped mowing is 30degrees.
Over on the side where grass is taller is steeper than 30degrees & NOT Mowable on my Zero.
That's where I use 4wd Tractor with all 4 fluid filled & a 10ft lift type Bush Hog Cutter mowing down & backing up then repeat.
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
MILLER XMT 350 WELDER (A55745)
MILLER XMT 350...
2010 INTERNATIONAL LF627 SLEEPER (A56138)
2010 INTERNATIONAL...
2014 FORD F-550 SUPER DUTY SERVICE TRUCK (A55745)
2014 FORD F-550...
1984 GROVE CRANE (A54607)
1984 GROVE CRANE...
