davegr62
Yes sir.. it was an old post but one of very few that showed a ZTR with tires other than the turf. I just picked up a ZD326s back in March when Kubota was offering the 0% financing. I have exactly 30 hours on it now and absolutely love it. I mowed last night with my B7500 and never realized how slow it was compared to the ZTR. I like the side discharge for what I'm mowing but rear is nice for mowing near the house and such.
I mow almost 5 acres and half of it is on a slope with a few steep areas. It goes up with no issue as long as I'm at a consistent speed. If I speed up too quickly the front wheels will lift off the ground some. The problem is going down. For the most part I can keep it controlled going down and found it easier to control at lower RPM. Once your traction breaks though, it becomes a littly tricky. Best thing I've found is to at least keep it straight and it will regain traction. I'm considering replacing the turf tires with something identical to your older ZTR. Not worried with chopping up the ground, I'm comfortable with turning and not tearing up much.
I may take your advice and lowering the tire PSI. I can see how that would help but I'm not sure how much additional traction I'd get to stop it from slipping going downhill. I bought a second set of rims to put the new tires on so I can swap back to turf easily if i needed to. I just need to decide on which tires I want, most likely the Carlisle Tru Power's.
