Loader Kubota
/ Kubota #3
Approx 2300-2800 lbs including the forks (depends on height)
I'm not sure where you are reading those numbers but that's not even close to truth. Generally Kubota FELs are numbered in the kilograms they can lift, so I'd bet the real numbers are closer to 800 lbs. for max pallet. And height wouldn't matter as much as how far forward of the pins the load is.
/ Kubota #4
From the link posted with the statement...
/ Kubota #6
Kubota B7800 Attachment​
Kubota B7800 tractor photo
2003 - 2008
B Series
Compact Utility tractor
Kubota LA402 Loader
Height (to pin):81.5 inches
207 cm
Clearance, dumped bucket:65.5 inches
166 cm
Dump reach:26 inches
66 cm
Dump angle:40°
Reach at ground:54.1 inches
137 cm
Rollback angle:26°
Breakout force (lift):1684 lbs
763 kg
Lift to full height (at pin):1060 lbs
480 kg
Bucket width:54 inches
137 cm
This is a tractor at least ten years old. Consider the possibility that a Loader hydraulic line ten years old could rupture without warning during a max lift.
About 750 pounds for a pallet with its midweight 500mm forward of the Loader pins to 81" height.
Perhaps 900 pounds for a pallet with its midweight 500mm forward of the Loader pins to 48" height.
Perhaps 1,200 pounds for a pallet with its midnight 500mm forward of the Loader pins to 6" height.
Have a minimum of 500 pounds counterbalance mounted on the TPH before attempting a max Loader lift.
/ Kubota
According to LA402 spec it's 1005 lbs minus loader weight minus bucket weight. It comes down to about 200 lbs. Can't believe it! Where am I wrong?
/ Kubota #8
I don't see those numbers in there. It does give numbers between 880 to 1060.
Yup, you are right. Was not paying attention and was looking at bucket numbers.
Lift capacity to max. height (Bucket bottom mid point), kg (lbs) .......... 400 (880)
Lift capacity (Bucket pivot pin, max. height), kg (lbs) .......... 480 (1060)
Lift capacity (500 mm forward, max. height), kg (lbs) .......... 345 (760)
Lift capacity (Bucket pivot pin, 1500 mm (59 in.) height), kg (lbs) .......... 600 (1325)
Lift capacity (500 mm forward, 1500 mm height), kg (lbs) .......... 455 (1005)
/ Kubota #9
Should be just the bucket weight not the loader weight. Bucket's probably 150-200 lbs for that size tractor/54" bucket?
/ Kubota #11
B7800 is a B series machine, it weighs 1600 lbs. No way it has a loader that is lifting twice the weight of the machine.
@CausticUrbanCoast it appears you read the bucket rollback force (force of the curl cylinder) which in no way determines the lift capacity of the loader itself. As previously mentioned that capacity is somewhere between 800 and 1000 lbs depending on how the weight on said pallet is distributed.
/ Kubota #12
Yeah I did.
However its 1325 at 59" off the ground, above that it is de-rated.
Capacity to do something and saftey doing it are different, most rams are far above rated capacity for safety. You will also see different loader ratings if a ballast box is listed.
/ Kubota #13
Incorrect information has the potential to physically injure a reader.
Go back and delete Post #2.
Not an option on my mobile version of Tapatalk, will do when I login on a computer though.
The forum moderators are free to strike/remove it until then.
The information to refer to was in the link. The information was also corrected in at least 6 other posts.
You should apply for the moderators job.
/ Kubota #15
/ Kubota #16
Keep in mind that the CG of the load on a pallet will be a couple feet out from the pins, and thus the capacity will be less as the lever arm is longer.
SSQA pallet forks weigh about 250 lbs. The 7800 probably does not have SSQA though. Forks that clamp on the bucket will have significantly less capacity than SSQA forks as they will place the load CG even farther from the pins.
/ Kubota #18
I've put on about 1,100 hrs on my B7800, in which case I feel like I have the background to comment on this..
As has been stated, the loader model is the capacity in kilos. No question that those are reliable numbers (at the pins!). I am not thinking that you can lift max without ballast: I have ballasted rears and I generally have an implement on the rear.
I had 3pt forks that I'd use on my bucket. I'd set the forks IN the bucket and chain the top link to a chain hook on the middle of the bucket. It would reduce the length of available forks but it allowed me to pick up a lot more weight. Not something that one should do w/o paying very close attention to things.
I got my NX because my B7800 couldn't lift my wood crates, well, it could, but just barely (not enough to stack or to lift on to my deck, but it could lift off the ground and I could move them around a bit).
If it's close to max then start thinking about either trying to lift/move less weight OR get a bigger tractor. Running around max things become unsafe: flat and straight is mostly OK, but deviate from this and it becomes dicey, no matter what tractor and loader.
/ Kubota #19
Are you using dedicated pallet forks or clamp on forks? Clamp on forks will lower your lifting considerably. Also how the pallet is distributed will make a lot of difference. You can lift a lot more weight with cement bags stacked on the lifting side of the pallet vs plywood laying flat. Lifting a 1000 pound close stacked pallet on dedicated forks to truck bed height would be your very maximum capacity and I doubt it’ll manage that.
2018 JOHN DEERE 310EL BACKHOE (A59905)
2018 JOHN DEERE...
2014 Ford Explorer SUV (A59231)
2014 Ford Explorer...
2018 Toyota C-HR Hatchback (A59231)
2018 Toyota C-HR...
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
John Deere 7410 (A53317)
John Deere 7410...
17102 (A56859)
17102 (A56859)
