kubotas littlest tractor
   / kubotas littlest tractor #11
Nice work, love to see the victor posing for the money shot /forums/images/graemlins/grin.gif
I can see she isn't shy /forums/images/graemlins/blush.gif
   / kubotas littlest tractor #12
I likes my BX23 too! And I imagine it'll get better when mow'n season starts /forums/images/graemlins/grin.gif
I can squeaze mine onto my 6x12 single axle by swinging the BH all the way to one side and placing the FEL bucket onto the front rail. And since I don't plan on hauling it around I decided to keep the trailer.
Now if'n I was going to start hauling it around on a regular basis then a twin axle car hauler w/brakes would be the ticket.
By the way, and I've asked this before, what is all that white stuff /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
The brown is turning to green down around my way /forums/images/graemlins/grin.gif
Volfandt
   / kubotas littlest tractor #13
Matt,
I've used a 4x8 trailer with my BX multiple times (with a 60" deck and the loader on) and it worked fine for over 80 miles rides. You're not going to need a 16' with aux brakes for a BX. A 12' would work; single or double axle is up to you. If there is a remote chance you might get a bigger machine in the future (B or L series), then maybe a 16' might be a better decision. 16' is a pretty big trailer though... Maybe rent or borrow one and see how it feels and tows before you cut a check.
There is lots of trailer talk in here /forums/images/graemlins/smile.gif
   / kubotas littlest tractor #14
I don't live all that far from the local Kubota dealer and imagine needing to take the BX2200 in for service no more than once every several years. I, therefore, did not want to invest tons of $ in the trailer. Since I have no backhoe and anticipate not needing to take the FEL in on most trips, I decided to go with a 5' x 8' Snow Bear from Home Depot for $599. I have no snow and the roads from here to the dealer are totally flat, straight, and mostly quiet rural roads on which I can cruise at 35 to 45 mph.
The trailer is quite versatile. Two ft. high sides are removable. The front and rear sides can be removed or flipped to act as bed extenders, increasing bed length to 12.5'. The bed is a tilt bed, while the rear side in its horizontal position has integral ramps, facilitating easy drive on and off. The bed not only pivots, but can be repositioned on the tongue for various tongue lengths. The rear axle can be placed in alternate positions on the bed as well. When I know I'm not going to use the trailer for a long time, I remove all side and end panels as well as the tongue. This goes pretty fast. I then use a worm-gear winch to pull the bed up vertically and chain it to an interior garage wall. It's amazing how little space it takes up.
There are no brakes, but brake lights, along with both front and rear turn signals work well. The main bed is a combination of steel with 2 stips of 3/4" pressure treated plywood screwed to a steel sub-frame. Tires are 21" dia. Weight is a little under 500 and gvw around 2100, so a BX with no bh subframe and no attachments is within specs.
Great little trailer. I like it.
   / kubotas littlest tractor #15
I found my 18' car hauler was cheaper than the 16' when I was shopping. It is the same trailer, only adds the 2' beaver tail on the back. These are heavy machines, and deserve some respect when towing.
Putting a BX on a lumberyard special 4x8 is risking too much in my opinion. I hope those that do this are careful. It can very quickly get out of hand and kill someone. $15,000 tractor on a $200 trailer, kind of like a $25 motorcycle helmet, means you have a $25 head. /forums/images/graemlins/confused.gif
My BX on the 18' trailer
   / kubotas littlest tractor #16
For the most part, I agree. You are really right about that word "careful". If I had to take this on the freeway, curvy, hilly, or icy roads, I wouldn't do it. I am within the legal gvw limits and on my straight, level, rural roads, I drive slowly for the few miles to the dealer. One consideration for me was that my tow vehicle will take just over a ton. A larger trailer would have meant a larger tow vehicle. Because of this, the $ factor was more about a new vehicle than a few hundred more for a bigger trailer. As far as motorcycle helments, motorcycles are not a risk I care to take at all, but I also don't feel the need to insult those who do.
   / kubotas littlest tractor #17
Tom, I have the same trailer as you and also find it to be a great little trailer. We use ours around the property for many things behind the ATV.
MarkV
   / kubotas littlest tractor #18
Looks like a great place you have in the mountains. The “little” tractor did a job on that snow you people in Maine seem to like so much. /forums/images/graemlins/crazy.gif
You might want to check the local rules about attaching the tractor to the trailer. I am sure the ratchet straps are heavy enough for that size tractor but here they would not be allowed by DOT. Not being critical, just trying to save you an expensive ticket. And no, I don’t want to say how I learned that. /forums/images/graemlins/frown.gif
MarkV
Caterpillar 2PD5000 5,000LB Diesel Warehouse Forklift (A53421)
Caterpillar...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
Miller Spectrum 500 DC Plasma Cutting System (A54811)
Miller Spectrum...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2019 Freightliner M2 106 8.5 CuYd Street Sweeper Truck (A53422)
2019 Freightliner...
