Kuboto RTV900
/ Kuboto RTV900 #1
cdj
cassopolis,MI
JD4650
how do I change the rear axle? do I need to remove the wheel holders?
/ Kuboto RTV900 #2
The rear axle assembly?
/ Kuboto RTV900
Yes, we had the crosses wear out on the universal joints on the right axle. Easy to pull the old shafts out (two pieces), BUT not enough room now to put new in (all together)
/ Kuboto RTV900 #4
When installing new (or rebuilt) assembly get the axle halves lined up on one side and then push that side together as far as it will go. You will then be able to get the other side to line up and slide it together. Make sure the axle halves are timed and hopefully you put u-joints with grease fitting in. If you had the older axle frame you need to drill holes to be able to grease outer u-joint.
Kubota SVL75-2 (A62180)
Kubota SVL75-2...
2012 Ford F-450 4x4 Altec AT200A 30ft Bucket Truck (A61568)
2012 Ford F-450...
2010 John Deere 1770NT Planter (A63109)
2010 John Deere...
2016 Ford Transit Van, VIN # 1FTYE1ZG8GKB07239 (A61165)
2016 Ford Transit...
2023 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2023 Peterbilt 567...
2018 Dodge 5500 Bucket Truck 4WD (A63118)
2018 Dodge 5500...
