I would imagine the procedure would be similar on other makes and models, but my rear roller bearing is shot on the right side. I have a replacement roller and was wondering if anyone has replaced this in the field without taking the track off? If I remove the grease fitting where you adjust the track tension and somehow get the tension loosened on the track, will there be enough slack in the track where I can simply unbolt the roller and drop it down under the track for removal? I hate the thought of having to remove the track all together as I will be doing this by myself or with a helper. These tracks are heavy to manhandle.
I've looked for videos, but the only ones I found were for track removal and replacements. Nothing for roller replacements.
