L-35 Kubota hand gas lever question..
   / L-35 Kubota hand gas lever question.. #1
mrbruce
NY
L-3400---- L-35......
Just bought a 96 L-35 Kubota, and need to know about the hand gas lever at the right side rear of the seat.
Seems like it should stay in one place while your running at what ever RPM, but it don't..
It don't seem to do anything different than the foot feed does, it just returns when you let off of it...
Any ideas ??
Thanks for your time.....
   / L-35 Kubota hand gas lever question.. #2
Should stay where you put it the tension device is in need of adjustment or repair
Yes, it sure seems to need that.
Not sure how that works, but I'll remove it and check it out..
Thanks...
   / L-35 Kubota hand gas lever question.. #4
Thanks...
Try to adjust 080/090.
  • Kubota_L35_Tractor_Illustrated_Master_Parts_List_Manual.pdf
Thanks for that, the8080, I'll see what I can do with it...
   / L-35 Kubota hand gas lever question.. #6
It should hold position and needs adjusting.
If you have a backhoe attachment make sure to lube the hand levers that release the backhoe attachment. It seems common that they rust up in time.
Also check the front axle gear oil.
Thanks for the info, no BH on the L-35, but the hardware is there to hook it to.
The L3400 has one and thats enough for me...
2024 JOHN DEERE 3039R LOT NUMBER 165 (A53084)
2024 JOHN DEERE...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53472)
2013 Doyle Dry...
2016 Ford F-550 Altec AT37G 37ft Insulated Bucket Truck (A52377)
2016 Ford F-550...
New/Unused 10ft 40 Drawer Workbench (A51573)
New/Unused 10ft 40...
New/Unused 7ft Stainless Steel Work Bench with 10 Drawers (A51573)
New/Unused 7ft...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
