L-39 FEL bucket hydraulic lines shield kit
   / L-39 FEL bucket hydraulic lines shield kit #2
So your dealer installed the shield kit for free? How did you work that one out.......
Your toolbox is metal....mine is a plastic piece of junk stuck on the side.
I pointed out that the hydraulic lines looked to vunerable when loading over the side of my dumptruck. Dealer knew I was a serious buyer. They said Kubota had built a kit to protect the lines and that they would install it free of charge upon me signing an agreement of sale.
I had no idea there was a cheaper toolbox. The metal one is the only one I knew of.
   / L-39 FEL bucket hydraulic lines shield kit #4
You just keep coming up with options I didn’t no exist for the L39. I’m also getting a bit PO’d at my dealer for not telling me about them when I specifically ask if there were any options available. /forums/images/graemlins/frown.gif
On the tool box I am having a hard time telling from the photo’s how it is mounted. It looks like the box mounts to a bracket and I don’t see any existing mounting holes on the FEL supports for a bracket. With out removing your box for a photo can you describe the bracket and where it bolts or is welded to the tractor?
Thanks,
MarkV
Sure. You're correct, the tool box mounts to an L-shaped pedestal. The pedestal is bolted to a piece of steel bar at a 90 deg angle. The steel bar has 2 holes in each end and is about 2" wider than the FEL post. Long bolts then go in the holes, past the front & back of the FEL post and into another piece of steel bar that is identical to the other first steel bar. It's just really a big clamp that holds the toolbox to the FEL post so no holes are drilled in it.
I'll see if I can get a pic up for you.
I guess you don't want to know about the optional horn kit & rear work lights kit, do you? /forums/images/graemlins/blush.gif
   / L-39 FEL bucket hydraulic lines shield kit #6
I'm Just so smart sometimes.
I had our shop build a real rugged version of the tool box holder.
Only one problem.
I mirrored the sketch and now have a nice "Step Platform" foothold when I climb up to refuel. The hydraulic lines would make getting at the box on that side tough. I will have to bribe the shop to make the bracket for the left side loader arm.
Symmetry is nice.
   / L-39 FEL bucket hydraulic lines shield kit #7
Thanks for the description of the tool box mount. A big clamp type of system sounds like a pretty easy thing to fabricate. I was looking at a collection of ammo cans that have accumulated over the years and thought that one of those might make a good poor man’s tool box.
No horn but the rear work lights were on the machine when I bought. The front and rear lights are pretty darn good too in my opinion.
Thanks,
MarkV
Mark,
Thanks, I know I'm just a "grasshopper" according to others, but I'll try to offer as much help as I can with my 30 yrs experience with tractors & trucks. /forums/images/graemlins/grin.gif
If money is not at a real shortage, consider the Kubota kit. I don't think you'll pay more than $60 for it. It's totally overbuilt, as is common with Kubota. An ammo can isn't a bad idea, though!
2023 John Deere Z994R (A53314)
2023 John Deere...
Etnyre 2000 Gal Asphalt Dist. Truck (A47477)
Etnyre 2000 Gal...
30" Metal Pipe (A53316)
30" Metal Pipe...
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A55851)
2018 Kubota...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
