tom9961
My L 5030 would not turn over to start. I could jump the starter and it would start and run fine.
I checked a safety switch under the cab. It is on the right side and if you press the switch button it will start.
Is this switch supposed to be depressed all the time? I can't find anything that moves when you depress the clutch that would press the button and engage this switch. There is a hole in the bracket were this switch is mounted that might have had some type bolt to adjust and keep the switch engaged.
Can anyone help? All I do now to start the tractor is have a buddy reach under the cab and depress this switch. It cranks and runs great. I just have to find out how to fix in case I don't have a buddy aroud everytime I need to use my tractor.
Thanks for any help you guys might offer.
