L1501 parts/dealers
   / L1501 parts/dealers #21
I bought mine abot 4 years ago. Engine has lots of hours and runs fine. If you change the oil about every 100 hrs or every 6 months and keep CLEAN fuel it should run many 1,000's of hours. I have a PTO that can be disengaged. I am not using the PTO as I have a kelly Back hoe on the rear end. Love the machine.
   / L1501 parts/dealers #22
Does anyone know the correct typ of battery this tractor is suppose to use? Crank power and stuff? I just bought one of these tractors and they had a car battery in it. Also is it suppose to charge the battery when it is running? Mine does not seem to be charging if it does
   / L1501 parts/dealers #23
I did put a new battery in and just used a car battery. Mine does charge the battery. The key must be on for this to happen. I once turned the key off by mistake and ran it for many hours and the battery went down. It was the old battery. It does seem to like a good battery so I would put in as large a battery as you can. I kinda went too small i think. Really need to use the glow plug to get it started.
   / L1501 parts/dealers #24
Ok thanks..I will keep an eye on it..Just replace the terminals and wires for both today.. What are the cranking amps you are using on your battery?
PLEASE VIEW ALL PICTURES!! (A50774)
PLEASE VIEW ALL...
2019 HINO 268 26FT BOX TRUCK (A52141)
2019 HINO 268 26FT...
2018 Chevrolet Malibu Sedan (A50324)
2018 Chevrolet...
Metal Platform (A50774)
Metal Platform...
Lull Highlander 1044C-54 Series II 10,000LB 4x4 Rough Terrain Telehandler (A50322)
Lull Highlander...
2014 Wabash Tanker Trailer (TITLE) (A50774)
2014 Wabash Tanker...
